MakeMKV and Its Alternative
2019-10-21 22:42:48     Posted by Nicole
1500
Summary: Are you still looking for a simple and solid one-click solution ripper to convert DVD that you own into a mainstream format so that you can play it everywhere? Then you shall put MakeMKV into consideration. An alternative to MakeMKV called DVDFab DVD Ripper can be one of your best choices, too. Now let’s dive in to read more.
You might start to consider digitizing your DVDs or Blu-ray discs when you see them gathering dust in a corner so that you can watch them on your phone or other devices anywhere, anytime. MakeMKV is not a bad choice to do this stuff. Yet other than this software, there are still lots of choices for you. We will guide you through the process, just to make it as simple as possible.
Part one: MakeMKV Overview
Regarded as one of the best DVD rippers, MakeMKV is a one-click solution to convert and rip DVD and Blu-rays. It is mostly known to people as being in beta for years. As a format converter or "transcoder", MakeMKV only offers one output format, lossless MKV, which can be told from its name. It rips and converts Blu-ray/DVD to lossless MKV that contains all the original data from the discs with no compression.
This software is currently on version 1.14.5 as of September 2019, and it is a possibility to download MakeMKV for Mac OS X and Windows. Users can also install MakeMKV on the Linux operating system by following a detailed instruction post on the MakeMKV forums. To download MakeMKV, you can go to its official website.
One thing should be highlighted is that MakeMKV contains both freeware and shareware functionality. You may use this software to convert or stream DVDs for free, as much as you want. Yet when it comes to Blu-rays, you may need to purchase a MakeMKV activation key after a 30-day trial period. When your trial period comes, you need to pay for $50 if you want to go on the using and you will receive a MakeMKV beta key. After that, you can use “Register” from “Help” in this software to enter it. If you only rip Blu-rays with MakeMKV occasionally and think it costs too much to buy this software, you can reinstall this software after 30 days to obtain a new trial period, as MakeMKV is a beta version.
Part two: Why MKV?
MKV is short for “Matroska”. Whether you are downloading videos from the Internet or getting them from other people, it is very likely that you will come across MKV files. MKV files are not an audio or video compression format as people always think. They are actually a video container, much like MOV and AVI, but also supports an unlimited number of audio, picture and subtitle tracks into a single file – even if those elements use different types of encoding. Apart from this, as MKV supports descriptions, ratings, convert art, and even chapter points, it is often seen as the carrier for high-definition online video. This is why MKV is chosen as the default video container format for the popular.
Another thing you should bear in mind about MKV files is that they tend to be really large in size, so your best bet for playing most MKV files is to use DVDFab Player 5. One of the most advantages of this software is its playback capability. DVDFab Player 5 uses top-notch media playback support on all the media formats, not only just MKV, but also MP4, MOV, VOB and more. In case you want to know more about how this software works to play MKV files, you are free to click the link here.
Part three: How MakeMKV Works?
MakeMKV is easy to use. Only one click is enough to finish the conversion process.
If you have installed this software on your devices, you will see this window below when you open it.
MakeMKV will automatically detect DVD or Blu-ray and show it if they already exist in the DVD drive. When your DVD or Blu-ray information shows up, you can click on the large optical drive icon to initiate the program and let the software begins scanning the drive.
Once the scanning process is done, all chapters of DVD or Blu-ray will show up. This is when you can do some settings, like selecting subtitles you need, choosing chapter you want or other things.
When you have done your selections, you can move your eyesight to the right side and you will see the “Output” folder – this folder decides where your output files go. Of course, you are free to change its directory if needed. Then click “Make MKV” to start the conversion. When the MKV file is made, you can use DVDFab Player 5 to play it right away.
Rip 4K/UHD with MakeMKV
You can also use MakeMKV to rip 4K/UHD. Blu-ray took over the place of DVD and offers people with higher resolution and clear image. However, people have never stopped their pursuit for higher resolutions, as a result, 4K shows up. 4K Blu-ray has grown in popularity worldwide day by day. If you happen to have 4K Blu-ray discs and want to rip them with MakeMKV, just repeat the above steps.
Outstanding Features of MakeMKV
1. This software is 100% free for DVD conversion.
2. Able to read the protected Blu-rays and standard DVDs
3. Compatible with Windows, Mac, and Linux platforms.
Drawbacks of MakeMKV
1. The biggest one is that this software is only for MKV files.
2. The software will no longer be completely free after the beta period is over.
Part four: Comparison with other similar software
The market is flooded with a lot of software to convert the DVDs or Blu-rays into the rip these days. Many applications are similar to MakeMKV. So many people have difficulty in selecting among them. Now we will make a comparison for you so that you will know which one suits you best.
MakeMKV vs HandBrake
HandBrake is a free and open-source transcoder for digital video files. It is developed to make ripping a film from a DVD to a data storage device easier. Furthermore, this software is also compatible with Linux, macOS, and Windows. Apart from this, HandBrake shares the same function to convert DVD to MKV file with MakeMKV. Yet other than that, HandBrake also supports users to rip DVD into MP4 format, another mainstream video format. Besides this aspect, they also differ in terms of time, space and speed. HandBrake takes a longer time to compress the video and the resulting file size is smaller than the source one. You might need to take longer to complete the process. On the contrary, MakeMKV does nothing to the source stream but only rip them into MKV file – a different container.
To make it clear for you, we summarized the pros and cons of HandBrake and listed them below.
Pros of HandBrake
1. Compatible with Windows, Mac, and Linux systems
2. Convert into both MKV and MP4 formats.
3. This software is totally free.
Cons of HandBrake
1. It can be a challenge for a beginner to use.
2. The conversion process takes a longer time.
3. The Graphical User Interface is not so easy.
MakeMKV vs AnyDVD
AnyDVD HD is also one of the most popular DVD ripping software on the market. It comes with the same functionality as AnyDVD, but with additional features for full Blu-ray discs and HD DVD supports, including decryption of Blu-ray and HD DVD movies. Unlike MakeMKV, AnyDVD HD is a Windows-based application that removes restrictions of DVD and Blu-ray media automatically in the background. As soon as a DVD or Blu-ray is inserted into the drive, AnyDVD will get access to the contents of them. In terms of prices, AnyDVD HD is more expensive than MakeMKV. Lifetime updates of AnyDVD cost $115 or else it’s 1-year updates for $60.
For your better understanding, we summarized the pros and cons of AnyDVD HD and listed them below.
Pros of AnyDVD HD
1. The intuitive interface makes AnyDVD HD easy to use.
2. DVD to MP4 converting speed is high.
3. Better output quality than others
Cons of AnyDVD HD
1. You are not allowed to share output video to social media
2. This software can only be available on Windows
Therefore, no matter MakeMKV, HandBrake or AnyDVD, they all have its pros and cons. You can select one according to your need. However, you may not want to limit yourself to only three options. There are other available options in your hand if you are not satisfied with the above three applications. DVDFab DVD Ripper is one of them.
Part five: MakeMKV Alternative
We are not forcing you to choose a certain software but we believe that the abilities will speak for themselves. Here are some information about DVDFab DVD Ripper. Please be more patient to read it. Maybe this software will surprise you.
What is DVDFab DVD Ripper?
Similar to HandBrake and MakeMKV, DVDFab DVD Ripper is also a DVD ripping software. But there is something that enables DVDFab DVD Ripper to surpass those two. This software can quickly rip and convert a DVD to any mainstream audio & video formats for playback on portable and mobile devices. Other than DVD, this software can also read ISO files. Most importantly, DVDFab DVD Ripper is so powerful that you can edit your video first before output them. For example, you can control the start and end chapters within the source, audio tracks, subtitles and set video prosperities, such as its brightness.
How DVDFab DVD Ripper Works?
Here is a step by step tutorial to rip and convert videos with DVDFab DVD Ripper.
1. To use this software, you may need to install it on your computer first. This application is compatible with both Mac and Windows. Download a version as needed.
        i  Free Download                                                        i  Free Download
2. Launch this software, click on the Ripper tab and load your source. DVDFab supports DVD discs, DVD ISO files, and DVD folders. So you can insert a disc and this software will detect this disc itself or you can click “+” button to load a source or drag & drop ISO file or folder to it. Once the source is uploaded, you are free to do the next step.
3. Now you may need to choose the options available to you as per your desires from Profile Menu. You can choose the device and format you want to output by going to the profile library at the top left corner. There are many devices available, such as iPad Pro, iPhone, Apple TV, etc. Speaking of the output formats, DVDFab DVD Ripper offers various output formats, like AVI, FLV, MKV and so much more.
4. Customize the video
As soon as the DVD source is uploaded, this software will start to detect it automatically and the main movie title will be selected by default. In case you have a need to rip other titles, you can click the “Choose Other Titles”. Furthermore, you can see a wrench icon standing for Advanced Settings. With one click of this icon, you can choose the output video resolution and other more settings. At the bottom of the interface, you can also select the path where you want your output file to be saved before conversion.
One thing needs to bear in mind is that you can edit your video with DVDFab DVD Ripper by clicking a pen icon-an editing tool- next to Advanced Settings option and going to an editing interface. On this new presented interface, you can change video properties such as its brightness; you can add text or subtitles on this video as well as for trim and crop video.
5. While your settings are done, you can click on the button of Start and wait until the process is completed. Don’t worry. The conversion time won’t last too long. In the end, the file will be saved at its destination.
To make you have a full understanding of this software, we have summarized its features below.
1. Supports multiple languages
There are lots of features of this software that come in really handy in your usage. The software supports multiple languages so that you can work with your favorited language including English, French, etc.
2. Friendly user interface
As soon as you launch the application, you will see an interface in blue with the entire menu bar at the top. The interface looks stunning and beautiful.
3. Easy to use software
You can learn how to use this software easily even if you don’t have much technical knowledge, even you haven’t done the conversion before.
4. Fast and professional tool
The video rendering is quite fast compared to other software. DVDFab DVD Ripper offers you batch processing, multi-threading, and multi-core, which makes the process less time-consuming.
5. Good quality video output
No one wants to compromise with the quality of the video. DVDFab DVD Ripper is capable of maintaining the video quality after conversion or ripping of the video file. So in this way, you can still enjoy high-quality videos.
6. Various formats
The output formats supported by this software are MP4, AVI, MKV, M2TS, and other popular formats.
We know that ripping and converting DVDs is not the only thing you want. To rip Blu-ray is also a thing you are looking for. For ripping Blu-rays, DVDFab Blu-ray Ripper can also give you a hand. DVDFab Blu-ray Ripper is a powerful and amazing tool. We have to admit that almost all commercial discs are protected. To convert protected Blu-rays, DVDFab Blu-ray Ripper definitely can help you with the help of DVDFab Blu-ray Cinavia Removal. Moreover, DVDFab Blu-ray Ripper shares a lot of commons with DVDFab DVD Ripper, for example, the output formats. They both support to output multiple formats.
What is DVDFab Blu-ray Ripper?
This software is a fully-featured tool with professional techniques. It can read any kind of Blu-ray Discs, ISO files, and folders and convert them as well as rip them. Under the help of DVDFab Blu-ray Cinavia Removal, this software can permanently remove the Cinavia watermarks from Cinavia infected Blu-rays.
How does DVDFab Blu-ray Ripper work?
This tool is as simple as DVDFab DVD Ripper to use. To use the Blu-ray ripper, you can use the same steps as you used with the DVD ripper. All work would be done. Here are brief steps for you.
1. Download and install DVDFab Blu-ray Ripper on your device as instructed.
2. Launch this software and select the “Ripper” tab.
3. Upload your source by inserting a disc or by clicking “+” or directly dragging and dropping ISO file/ folder.
4. Then select a module from Profile as well as an output location.
5. Then the last step is to start the progress.
What is DVDFab UHD Ripper?
When you have tried both DVDFab DVD Ripper and DVDFab Blu-ray Ripper, you will notice that you start the steps from the Ripper module on DVDFab 11 no matter rip DVD or Blu-ray. That’s right. These two applications belong to DVDFab 11, so does DVDFab UHD Ripper. Instead of using MakeMKV to rip 4K/UHD, DVDFab UHD Ripper is also a professional software you can ask for help. This software can convert 4K UHD into MKV/M2TS/MP4 formats, with lossless or 4K HEVC 10-bit or SDR video quality. If you have known how to rip DVD or Blu-ray, then you will know how to rip 4K/UHD with DVDFab UHD Ripper because they share so many commons. If you are still confused about how to rip UHD Blu-rays with DVDFab UHD Ripper, you are free to click the link here.
Part six: Conclusion
With good software, you can yield twice the result with half the effort. Since the market has been flooded by converters and rippers, it may take you a while to weed through them one by one. If you happen to need a converter or ripper, no matter for ripping DVD, or Blu-ray or UHD, you can read this article and find the right tool in your need.
1. Convert DVDs to MP4, MKV, and etc., to watch on PCs, portable & mobile devices
2. Extract DVD audios to AAC, MP3, and etc., to listen on iPod, or other music players
3. Customize the audio & video parameters to meet specific needs from different users
4. Edit the output videos like cropping, trimming, adding text/image watermark, and etc.
You May Need Other Tools
DVDFab DVD Cinavia Removal
It is the world's best and complete DVD Cinavia removal solution that can detect and then remove Cinavia watermarks from infected DVDs.
This is a software that can completely and permanently remove Cinavia from Blu-ray discs, so that you can enjoy the backups anytime, anywhere.
DVDFab Player 6 Ultra
This software possibly is the world's best 4K UHD media player with menu & HDR10 support on 4K Ultra HD Blu-rays.
