How to Extract Subtitles from MKV Files?
2019-03-19 04:05:52     Posted by Rebecca
3987
Summary: Extracting and adding subtitles may seem like a difficult job but it’s actually easier than it sounds when you’re using a right MKV subtitles extractor. Now follow us to see how to extract subtitles from MKV files.
Subtitles are one of the best features in a movie as they allow you to watch it and understand what’s going on even if you don’t know anything about that movie’s original language. However, every now and again you might run into a situation where a movie doesn’t have very good subtitles and you may want to edit them or replace them with different ones. But in order to do that, you first need to learn how to extract subtitles from MKV videos so that you can then add them to a different file. Extracting and adding subtitles may seem like a difficult job but don’t worry because it’s actually easier than it sounds when you’re using the right set of tools.
Part 1: How to Extract Subtitles from MKV with DVDFab Video Converter
DVDFab Video Converter is a tool that comes with many great features, including the ability to extract certain types of subtitles. Although primarily a video converter, the software can also be used to extract audio, edit and customize videos, extract subtitles from MKV and many other file types, and more. The software also supports pretty much any type of format you can think of, including 4K and 3D. Here’s how the subtitle extraction feature works:
1. Open DVDFab 11 and go the Converter module. Load the video you want extract subtitles from using the “Add” button or by simply dragging the file into the main UI.
extract subtitles from mkv
2. With the file now loaded, click the wrench icon to bring up the Advanced Settings menu. Here, look towards the button for an additional sub-menu related to subtitles. This menu contains multiple options but for this particular scenario, we’re going to need the option labeled “Extract to idx/sub file” so make sure you pick that one. While you’re there, feel free to make any other changes to the file and then click OK to save your changes.
3. We only want to extract subtitles from an MKV file in this example but you can use the Profile Switcher in the upper right corner to also convert your files to a different format, however, keep in mind that the Video Converter can only extract subtitles from certain formats. Another optional step is to open up the Video Edit menu in order to trim or crop the file while you’re at it.
4. Regardless of whether you just want to extract subtitles from the MKV or you want to make any other changes, pick a destination folder from the bottom menu and then click the Start button to begin the extraction process.
Part 2: How to Extract Subtitles from MKV with MKVToolNix
MKVToolNix is a collection of tools designed to help users manipulate MKV files. The software contains tools for everything ranging from editing and merging files to splitting, demuxing, and extracting subtitles. The downside of MKVToolNix is that you need to be somewhat tech-savvy in order to use it as this is a command line tool that looks fairly intimidating to inexperienced users. However, you can make things a lot easier by combining MKVToolNix with GUI software like MKVExtract or Inviska MKV Extract. We recommend Inviska because it’s minimalistic and very easy to use.
1. First things first, make sure you download and install the correct version of MKVToolNix for your specific operating system and then do the same for the Inviska MKV Extract software.
2. Open Inviska and click File -> Add Files to load the files to extract subtitles from. Under File, there’s also a Preferences option that lets you make certain changes to the files so use that as well if needed.
3. In to extract subtitles from the MKV files you loaded, click the little arrow next to one of the files to open up a new menu. Check the box next to the subtitle track you want to extract (you can select multiple if available) or use the batch extract options to the right if you’re working with more than one file. Also, use check the Extract timestamps and Extract cues boxes if necessary.
4. Click the little folder icon at the bottom to select the destination folder and then hit Begin to extract subtitles from the MKV files you selected.
Part 3: How to Edit, Remove and Add Subtitles to MKV Files
Now that you know how to extract subtitles from MKV files it’s worth learning a bit about how to edit, remove or add them because it’s very useful to know about these aspects as well. Luckily, you don’t need to use a bunch of different tools in order to perform these tasks because you can do all of them with DVDFab Video Converter. In addition to subtitle extraction, the tool can also be used to add or remove subtitles from MKV files, edit them, and convert files along with any subtitle tracks you choose to keep. Here’s an example of how to add them using slightly different steps than in the earlier example:
1. Just like before, open DVDFab 11, go to the Converter module and load the MKV file/s you want to add subtitles to.
2. Open the Video Edit menu and then click the Subtitle icon to load the subtitle file you want to add to the video. Pick a suitable file and then use the options menus to edit and customize the subtitles if necessary. Click OK to save the changes.
3. Go back to the main UI and check under Subtitle to make sure the right track is selected. Here is where you can also remove subtitles if needed, which is done by clicking the None option.
4. Pick the destination folder, click Start, and wait until the software finishes processing your file.
There are multiple tools out there that allow you to extract subtitles from MKV files but only a handful of them are truly worth checking out. We recommend first trying DVDFab Video Converter because it’s one of the most powerful tools out there when it comes to handling subtitles. MKVToolNix is a decent alternative but it’s pretty difficult to use and requires installing multiple GUI tools if you want to not only extract subtitles from MKV files but also edit, add or remove them. Meanwhile, DVDFab Video Converter can do all of that while also allowing you to convert and edit the videos themselves so don’t hesitate to give it a try.
You May Need Other Tools
DVDFab DVD Ripper
DVDFab Blu-ray Ripper
DVDFab UHD Ripper
  • Discount
    Copy & Paste Coupon Code:
    AUSW-FAB-OFF
    When Checking out.
    Aug 19, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
    The Universal Master Key to
    Access Protected DVDs & Blu-rays
    Price: $69 Buy Now
    World's Best DVD Combo to
    Tackle All DVD Copying/
    Burning/Cloning/Ripping Issues
    Price: $84.9 Buy Now
