Rip Blu-ray for Google Nexus 7
2017-08-03 22:32:23
7 inch HD backlit IPS display, 1200*800 in resolution and an impressive 216 ppi, how do these specs sound to you? Right, it comes from the Nexus 7, Google’s first tablet. If you are not an Apple fan and are not a massive screen lover, then this 7 inch tablet probably is your best fit. On the hardware level, it gives you enough storage space and battery horse and CPU power to do almost everything you can do on a PC, and what’s more, it is portable! On the software level, it runs Google’s latest Jelly Bean, a really sweet operating system. So, why not a good choice! Its HD capable display yields very positive video quality, making watching Blu-ray equivalent videos on it a reality. Now, the only thing you need is one Blu-ray Ripper software to help you rip any Blu-ray to Google Nexus 7 compatible video files, and DVDFab Blu-ray Ripper is an expert on that.
Check out the instructions below to learn how:
Rip Blu-rays for Nexus 7: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Rip Blu-rays for Nexus 7: Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the Blu-ray you are about to convert;
Rip Blu-rays for Nexus 7: Step 3 -> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find Nexus 7 from Profile Library and press "OK" button, then just hit  “Start” button at the Main Interface to go converting.
Note: selecting Nexus 7 profile from the built-in Profile Library is the key point of the whole process.
Product you need order: Blu-ray Ripper
For more information, please refer to DVDFab Blu-ray Ripper page.
  • Discount
    Copy & Paste Coupon Code:
    SEAM-FAB-OFF
    When Checking out.
    Sep 16, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
  • DVDFab DVD Copy
    Fast
    Easy
    High Quality
    Free Download
