How to Rip and Convert DVD to AVI with DVD to AVI Ripper?
2019-03-11 04:52:31
Sometimes you may need to convert DVD videos to video in AVI format to play it on your tablet or other portable devices, do you? DVDFab DVD Ripper is an excellent tool for users to convert DVD to AVI. You can try DVDFab DVD Ripper.
Step 1: Load a DVD source
Run DVDFab 11, go to Ripper module and load the DVD source.
Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
how to rip and convert dvd to avi
Step 2: Choose AVI format
Navigate to the profile library on the top left corner of the main interface and choose Format > Video > AVI format.
Step 3: Customize your video
Now it’s time for you to customize your own video. You are free to choose the titles you want, change the title name, and select the chapters, audio tracks and subtitles you like. You can also click the “wrench” icon to open the “Advanced Settings” panel to customize your settings and use the built-in editor to edit the video.
Step 4: Select an output dictionary
Navigate to the bottom of the main interface and click the “Folder” icon to select an output directory for you AVI video.
Click the “Start” button to start the process of ripping and converting DVD to AVI with DVD to AVI Ripper.
Please refer to DVDFab DVD Ripper if you want to get more information about how to rip a DVD.
