How to Decrypt DVD with DVDFab DVD Copy?
2019-01-14 22:43:27
If you want to decrypt your legally bought DVD and copy it for personal use, you can choose DVDFab DVD Copy. It is a powerful DVD copy tool that can circumvent any known DVD protections and make DVD copies that can be played with any DVD player or playback device. The following tip will show you how to decrypt and copy DVD with DVDFab DVD Copy.
Step 1: Choose a copy mode
Run DVDFab 11, choose “Copy” module and click the "Copy Mode" tab on the top-left corner of the main interface to choose a copy mode. You have 6 modes (see Note at the end) to choose. Here I take Main Movie mode as an example.
decrypt dvd
Step 2: Load a source
Insert a DVD into your optical drive. Then DVDFab DVD Copy will begin to analyze and decrypt the DVD automatically. The DVD will be decrypted completely within a few seconds.
dvd copy
Step 3: Customize your DVD
After the source is loaded in, the longest title, namely the main movie, will be selected by default. Now you can choose the chapters, audio tracks, subtitles, and make advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
decrypt dvd
dvd copy
Step 4: Select a directory
Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "Folder" icon is to save the output as a DVD folder on your hard drive; to select a directory by clicking the "Image" icon is to save the output as an ISO image file on your hard drive.
dvd copy
If you choose to save the output to a blank disc, you will be promoted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the clone process. Please refer to DVDFab DVD Copy for more detailed information.
Note:
6 modes:
Full Disc: copy all contents of the disc/ISO/folder source.
  • Discount
    Copy & Paste Coupon Code:
    SEPM-FAB-OFF
    When Checking out.
    Sep 23, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
  • DVDFab DVD Copy
    Fast
    Easy
    High Quality
    Free Download
