How to Rip Blu-ray to Samsung Galaxy Note 4?
2017-08-03 22:32:23
Samsung Galaxy Note 4, a smartphone from the Samsung Galaxy series with 5.7-inch 1440 x 2560 display powered by 2.7 GHz processor alongside 3GB RAM and 16-megapixel rear, has a strong capacity to run multiple apps, and presents users the realistic video effect with its big full HD display and high resolution. All kinds of video sources, even if the big-size and high quality Blu-ray movies, are well performs by Samsung Galaxy Note 4.
For viewing Blu-rays with your Samsung Galaxy Note 4, DVDFab Blu-ray Ripper, a powerful and up-to-date Blu-ray ripper software, shall be an indispensible partner foryou.
Next, please check this guide below to see how to rip Blu-ray to Samsung Galaxy Note 4 with DVDFab Blu-ray Ripper.
Step 1: Run DVDFab Blu-ray Ripper, and load the source
Run DVDFab 9, and opt for Ripper when it runs. Then insert the Blu-ray disc into the external Blu-ray drive attached to your PC, or drag & drop the ISO file or folder into the program. Also, you can load the source by clicking the "+" or "+Add" button to navigate it in.
Step 2: Choose Samsung Galaxy Note 4, and make settings
Seconds later, the source is in. Then go to the left pane and click the profile switcher to enter into DVDFab's profile library. Choose the destination Samsung Galaxy Note 4 following: Device -> Samsung.
Behind the profile switcher is the entrance of Advanced Settings feature DVDFab provides, by clicking it, you can set the video and audio parameters including resolution, sample rate, bit rate, video quality, codec, etc., for the output Blu-ray.
If you have higher and more specific need regarding the output Blu-ray, then DVDFab's video edit feature will help you with that. You can adjust the video effect to your ideal level, cropping or trimming the video, adding external subtitles or watermarks to brand the video.
After settings, move down to the lowest interface, and click the folder icon to define the output directory at the Save to part.
Step 3: Start running the DVD to Samsung Galaxy Note 4 ripping
Click on the Start button at the bottom right corner, this DVD to Samsung Galaxy Note 4 ripping will be started immediately and finished with the leading processing speed thanks to DVDFab's abilities of batch conversion, multi-threading, multi-core processing, and the support of the newest NVIDA and CUDA technologies.
OK, that's all! Now, just transfer the output video to your Samsung Galaxy Note 4 and check the output video quality. Almost lossless, right? Then just go on enjoying the video, have a nice time!
For more information, please visit: https://www.dvdfab.cn/blu-ray-ripper.htm.
  • Discount
    Copy & Paste Coupon Code:
    SEPM-FAB-OFF
    When Checking out.
    Sep 23, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
  • DVDFab DVD Copy
    Fast
    Easy
    High Quality
    Free Download
