Universal DVD Converter
2018-05-05 07:02:10
A universal DVD Converter should be powerful enough to convert any DVDs to any popular video/audio formats and devices, versatile enough for users to customize their videos in their ways, and fast enough to output high-quality videos in a few minutes. DVDFab DVD Ripper is such a universal DVD converter with all the features and tools you need. With an intuitive interface, it is also very easy to use. Now let’s go to check the detailed conversion steps of ripping a DVD.
Step 1: Load the DVD source
Run DVDFab 10, go to the Ripper module and add the DVD disc/folder/ISO file you want to convert.
Step 2: Choose a profile
Go to the profile library on the top left corner of the main interface, and select a profile you want. You can click the Format tab to select a video/audio format, or you can click the Device tab to choose a preset profile for a certain device.
Step 3: Customize your video
Once the DVD source is loaded in, the main movie title will be selected by default. But now you are able to choose other titles. Then you can change the title name and choose the chapters, audio tracks and subtitles you want. You can also click the “wrench” icon to customize your settings and click the “editor” icon to edit the video freely.
Step 4: Select a directory and start the ripping process
Go to the bottom of the main interface and click the “folder” icon to select a directory to save the output video. And then you can click the “Start” button to start the process of converting the DVD to a video format.
If you are also interested in converting Blu-rays to all kinds of video/audio formats, you can click Blu-ray Video Converter to learn more.
  • Discount
    Copy & Paste Coupon Code:
    SEAM-FAB-OFF
    When Checking out.
    Sep 16, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
  • DVDFab DVD Copy
    Fast
    Easy
    High Quality
    Free Download
