Video to Audio Converter
2018-03-09 06:16:52
I guess there are times you may want to extract an audio clip from a video file and use it as your ringtone or as the background music of your home-made video. To convert videos to audio files or extract your desired song from a video, a good video to audio converter is necessary.
DVDFab Video Converter is a professional video to audio converter which can convert all sorts of videos including MP4, AVI, MKV and more to audio files like MP3, AAC, FLAC and more. It is fast, easy-to-use and versatile, and anyone can learn it quickly and find the feature he or she need easily. Now let’s see how to use this video to audio converter.
Step 1: Load the source
Run DVDFab 10, go to Converter module, and load the video file you want to convert.
Step 2: Choose a video format (optional)
If you want to extract the entire audio track, you should skip this step and go to Step 3 directly.
Go to the profile library on the top left corner of the main interface, click Format > Video > General to choose a video format randomly. Click the “editor” icon to go into the editing panel, choose the “Trim” tab, and drag the sliders to choose the video (audio) part you want. Click the “OK” button.
Step 3: Choose an audio format
Go to the profile library, click Format > Audio to choose an audio format you want. Here we take the MP3 format as an example.
Step 4: Customize your settings
Now you can rename the video (audio) file and choose the audio track you want. You can also click the “wrench” icon to set the parameters like codec, sample rate, channels and volume.
Step 5: Select a directory and start the converting process
Move to the bottom of the main interface, and click the “folder” icon to select a directory to save the output audio file. Then you can click the “Start” button to start the process of converting the video to MP3 audio.
Now you can leave all the rest work to DVDFab, and it will complete the conversion process in a few minutes, even a few seconds if your video source is small.
If you want to convert Blu-ray movies or music Blu-rays to audio files for playback on top-notch acoustic system, we recommend you a powerful converter – DVDFab Hi-Fi Audio Converter, which can convert your Blu-ray collections to lossless FLAC or WAV audio files.
① Convert videos from one format to another for compatible devices
② Extract the audio tracks from videos and output as audio files
  • Discount
    Copy & Paste Coupon Code:
    SEPM-FAB-OFF
    When Checking out.
    Sep 23, 2019
  • DVDFab All-In-One
    Gift 1: $30 Amazon Gift Card
    Gift 2: 5-Computer License
  • DVDFab DVD Copy
    Fast
    Easy
    High Quality
    Free Download
